Tuning with the EBL
Re: Tuning with the EBL
Lately Ive had some trouble with my IAC counts. I'm shooting for 5-10 and usually it will settle there and other times its 10-20. Its a new IAC but I never did the steps Ive read online to reset it? I didnt think I needed ti since it was new? Is the procedure the same with the EBL as far as pinning the a & b diagnostics ports?
Car: 1983 G20 Chevy
Transmission: 4L60
So can anyone suggest a sa table I should strlart with ? I'm going back to track tomorrow night ! I need this thing to pull some decent numbers ... help !!!
Running TFS super 23 175cc heads and 214/218 cam with 10.5:1 compression
91' bird 305 TBI T-5, trick flow heads, 4.10 gears, full UMI setup, track times coming soon!
7.4L TB...
Car: check
Engine: check
Transmission: check
RBob.
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
So as far as adjusting the steps go I can adjust the throttle stop screw and should I immediately see the changes on the wud or after cycling the key and engine on and off?
key on engine off you should see the new steps on a twist of the TSS. If you adjusted the steps in .bin you need to reflash. Unless the car shows a diff coolant temp due to cool down then steps will vary.
Car: 1990 gta
Engine: 383,tfs heads,hsr
Axle/Gears: 12 bolt 3.73
thanks..im trying to get an all out performance out the lil engine....seems to roast the drag radials more than before...working on my sa main and extended tables now, just a question why when I fill the sa main table across the board with lets say 38* from 2000rpm to 4400rpm on the wud it only actually shows 28* timing in that rpm range
the numbers on the table are actually not the timing but a percentage?
im lost...
I tried putting 60* on table and in the wud it shows actually 38*...I don't have a knock filter so no knock counts for me im doing all by ear...lol
im lost...
well i been trying to figure out why i have 60* on my sa main table and only 38* on my wud...here is my .bin
can anyone read it and let me know what im doing wrong thanks for the help.
Car: check
Engine: check
Transmission: check
I'm looking at it and the only thing I see is that the "SA - Coolant Comp Bias SA" needs to be zeroed out. If the engine RPM is in the area (600 - 1000 RPM) where the SA in the Main table is 47.81*, that is the issue.
Sub off the 9.84* bias and it is 37.97*.
RBob.
RBob.
RBob-is the ebl logic the same as gm on the air injection?
I'm in Kalifornia, so running all smog-in researching the gm logic it looks like it injects air to the headers during warm up/ all open loop, then on closed loop it diverts air to the cat. Diverts out if rich op/code set/decel/or high rpm when press greater than the relief valve.
I've tried both open and closed loop-the learn always has to shift the ve tables between the two; which has been frustrating me no end. However the gm logic makes sense of what it's been doing. If it's sending air to the headers then it would essentially be like an exhaust leak sucking in false air to the O2 sensors. Also I'm running a smog legal supercharger, so it taps air from the sc's pressure relief valve to feed the air system instead of the original smog pump-so it gets plenty of air.
So if air logic is the same, then I'll only learn the ve tables in closed loop.
Am I reading this correct?
Details:
The EBL P4 system sends ECM data to a laptop or PC running the What's Up Display program. It is simply the best and fastest data logger available for GM ECMs. The data stream contains all available engine and vehicle parameters.
Included on the EBL board is eight analog input channels. The data from these inputs is included real time with the ECM data. These analog inputs can be used for data logging WB O2 units, fuel pressure, and any other 0 to 5V linear device (accelerometer, oil pressure, oil temperature, suspension travel, and so on).
The software to run the engine is the result of years of effort. It has been enhanced to support engines from stock through high performance monsters. Handles boost to 30 psi. The EBL code provides functionality not found in stock ECMs. Wet N2O control, lean cruise, cranking prime pulses, ability to select open loop modes for cruise, deceleration or idle.
For example:
A real shift light
Soft touch rev limiter
1, 2 and 3-bar MAP support with boost SA retard and fuel multiplier tables
Spark tables are high resolution and full size up to 6,400 RPM
VE tables are high resolution and full size up to 8,000 RPM
Acceleration enrichment (AE) tables have been expanded
Changes to the fueling algorithms have been made to provide a smoother, stronger running engine.
Electric fan control for 2 fans
N2O wet system control: minimum MPH, TPS threshold, RPM window. Arming input
Smart A/C control: PE disable, upper/lower RPM shutoff, re-enable delay
Lean cruise mode for better fuel mileage
Open loop fueling modes
N-Alpha mode
Emissions functions: EGR, CCP, A.I.R. and closed loop fueling
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
my bad, i wasn't aware the P4 was offering AIR support! i was a bit too hasty then, sorry.
Car: check
Engine: check
Transmission: check
to cat-con
to port (exhaust manifold)
to atmosphere (divert mode)
When the engine is first started and the ECM is in open loop, the air is directed to port. It's been a while since I've looked at this, but IIRC, when in PE mode, or over a certain load or RPM, the air gets diverted.
Once the ECM goes closed loop air to port is never used again. For the most part it goes to the car-con. With the exception of high RPM/load or PE mode, at which time the air gets diverted.
Best bet while tuning is to set the enable CTS high, this forces the air to always be diverted.
RBob.
Car: 1990 gta
thank you again you been an efi god....
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Car: 1990 gta
im having a lil dilema...i took my engine out to fill the block with cement and a cam change and some new main cap arp studs...when i put it back in the car i put the balancer at 6* btdc on #1 and phase the distributor to #1 plug...got car started it runs ok with old tune up..but when i unplug the tanwire to check timing it dies!!!...with the tan wire connected it shows 6* btdc...so with the ebl i dont have to unplug the tan wire to check timing?
also when i rev it ,it stays at 6* but my sa main table its at 32*
and on the wud shows exactly that...how come timing is not picking up at the crank when i rev it up?
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
Car: 1990 gta
[quote=1991sleeper;5765906]Sounds like the ebl is not advancing timing ... have u checked all ur connections wiring etc.
everything is pluged in...what wires are the ones that advance the timing?
the ones that plug into the dist?
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
Engine: LS1 / L03
kevm, same way i got it. i'd suggest trying to advance the distributor with the EST (tan wire) disconnected until it will start (watch out for flooding), and then go from there.
btw some engines have a misleading way of timing indication. or shall i say some combinations of timing cover tab and balancers.. it may read way off when using an early style balancer with a late style timing tab or vice versa. i forget by how much but i'm just throwing this out because it threw me way off and took a while to figure it out on a buddy's Blueprint 355 crate.
Car: check
Engine: check
Transmission: check
Stalling when opening the EST/BYPASS connector with already low timing will easily cause the engine to stall. To rough in the timing first leave the EST/BYPASS closed, look at the WUD's SA value, and rotate the distributor to match.
RBob.
Car: 87 Suburban 2500
Engine: 455 Wildcat ( somewhat modified ))
Transmission: TH400 ( for now )
Axle/Gears: 4.10 ( for now )
Yes. The adapter itself from Innovative was essentially a solid stainless steel O2 sensor (in shape), and the only two openings were where the wideband screwed into it, and on the bottom of the adapter itself, which is just a small hole on the bottom. Not the very bottom as if facing downward, but near the bottom on the side of the unit, and that little hole on the side needed to face towards the turbine otherwise a faulty reading would occur. The top of the housing that remains out of the pipe has a small arrow that is lined up with that little hole on the bottom, this way you know which way it is facing. My friend has one, but he won't just sell the adapter without selling the whole kit...
Keep the sensor close enough to the exhaust ports as practical for fast response, while at the same time keeping it far enough out of the exhaust stream to not burn it up....
I'd weld a stub onto the exhaust pipe. Just a "T" type thing just long enough so that the end of the sensor is about 1/8 inch out of the pipe. Maybe 1/2 inch. I don't really know, nor am I really qualified to guess. Weld the bung on the end of this stub, so that when the sensor is screwed in, it senses the flow past it, but not directly on it.
Then, I'd slip onto that stub a heat sink, something like this one...
http://www.qualitekengineers.com/rou...nk-499549.html
I'm not enough of an aerodynamic engineer to guess how big of a hole in the end of the stub, but it seems the smaller the better heat isolation, while at the same time it seems that a small hole would slow the response. I dunno.....
For me, I'd likely want something that screws together, so that the length of the stub can be changed, like a screw in plumbing nipple, and leave the hole in the end full size.
The longer the stub, the better the isolation. ( or so it seems )
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by Cflick
If I understand the objective..... ( keep the sensor from being torched to death while having still fast enough to run the engine ) Keep the sensor close enough to the exhaust ports as practical for fast response, while at the same time keeping it far enough out of the exhaust stream to not burn it up....
http://www.innovatemotorsports.com/x...cat=250&page=2
I actually found it, took long enough too. Here is a link w/description...
OTOH, as long as it works.
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Hey all, So ive been busy squaring away other problems on the f-body. Still having my cold start issue, which i believe i finally found my vacuum leak. When i press the brake pedal in at park, my rpm slightly increases? Going to re do my brake booster lines as one is actually kinked up. But thats not the issue i finally found. So after doing a cold start with my buddy around (old school mechanic) he believed something was going on with my Spark, well we hook my labtop up next morning and fire up Ebl WUD. Start the car, with out putting my foot on the gas just slightly to keep it alive, the rpms shutter and hunt between 400-1000 pretty radically, but i noticed my Spark advance was jumping up and down from 20 to 4 and any number in between, while this was going on Spark Retard was going up to 4-6. Once i put my foot on the gas slightly it evens out and spark advance remains constant. Once its warm it never does it again. Could it just be the vacuum leak (cold air) causing it to be very radical and once warm it doesnt affect it? Or is there something within the spark system that can be caused by cold weather?
I use the idle spark for just exactly what you're describing. It essentially disables corrections at idle, resulting in a static, fixed spark advance at idle. The engine still hunts a bit due to the cam, ( more of a rolling surge sometimes, but not all the time ) but the idle is much, much smoother as a result of a fixed idle spark at a reasonable number, like 22 or so. ( more or less depending on what works for your engine )
Another option for rolling idle improvement is open loop idle. That command a set A/F with no NB 02 sensor feedback. I believe there is a flag to check.
There's both a start-up and idle spark settings.
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
With cammed engines I try to tighten up the inputs. As an example, in the LT-5 there are are spark tables adding/removing timing depending on the rpm error.
I reduce the amount of timing in those tables to prevent the idle from running away and compounding itself.
Guys quick question, I spliced the secondary fan control in the back of the ECM, but now I have to relocate the secondary fan switch wire that originally leads to the passenger side cylinder head. I pulled that secondary fan switch out because of the turbo, as I wanted to eliminate all connection locations from the heat, but I never got around to relocating to the front of the intake manifold, and of course now I cannot find where I placed that switch. Don't wanna by another secondary sensor if I can just splice the secondary fan wire into the primary fan control sensor, the coolant temp sensor. What do you guys think, or should I just pony up the cash for a new secondary fan sensor...
Edit: RBob just reached out to me and told me what needs to be done, will wrap things up in a few minutes and follow up with the results...
Edit II: Bad secondary relay, despite clicking when tested, it was bad. Replaced with a new unit, and the system works flawless, no need to connect secondary fan switch wire...
Car: 1990 gta
this might sound stupid..lol...but the other day I took my dash apart and when I put it back together somehow I lost the small nut that holds the connector for the usb port cable on the eblp4...where can I get one of this?
I looked thru elctical stores...none of the ones I tried worked...rbob can I buy any from you?
thanks.
thanks.
Car: 1991 Pontiac Firebird
Engine: 355 TBI
Transmission: 7004R
Axle/Gears: 3.27/42 ?
Hello all,
I've been having an issue with my car that I believe could be either a lack of fuel or spark. The engine hesitates when I give it a lot of throttle and if given enough throttle, it will backfire from both the throttle body and the exhaust.
I replaced my spark plugs this week to no effect although I did come to find that the old plugs were extremely wet. I know my tune has too much AE but this is something that's always existed.
I use to be able to do WOT throttle runs and would have a slight pop from the exhaust but the engine would pull fine after the AE fuel decayed.
Today, if I try to do a WOT run, all I get is a bunch of chugging and pops between intermittent accelerations, and for the first time during WOT, my WB is reading lean.
I've been going through all of my previous pictures of changes I made to my car and I cant find any changes that were made around the time that the issue began. It makes me think that either something is clogged or something is faulty in regards to spark/fuel.
Just wanted to post here to see if anything could be spotted in my datalog before I create my own thread.
I'm thinking I might install an FPR monitor in the dash or EBL so I could monitor FP realtime and see if its dropping off during WOT. Any ideas or suggestions would be helpful.
Thank you!
Thank you!
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
On another note, i was watching Playback from a Datalog from the other day, and notice that once i go WOT, my DC% jumps instantly and is always hitting 100%+ around 3000rpm, i seen 103%DC the other day; is that even possible? If not why does it even show the value of 103? Any who looks like im out of fuel very early?
( unless, of course, you can actually hear detonation )
At around 90% ( more or less ) injectors go "static" and control is totally lost.
( means they simply do not have time to close and open again, so they effectively stay open, but not fully open as they try to close. )
Static injectors flow a lot of fuel ! If you're still going lean, then you need bigger injectors, higher fuel pressure, or both.
Strive to keep the injectors below 85% or so under the most demanding conditions.
( that would be WOT high load high RPM )
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Possibly a little rough, causing vibration, causing the exhaust to bang on the frame, or some such ? I'd look for something mechanical due to cold idle vibration.
That's telling you that the comfuser is calculating that you need 103% of what's available.
Damn ok i dont think 3K Rpm is high rpm lol, im running out pretty early no? If max should be around 85% that means my motor was asking for 18% more fuel at that moment? When they go static is that bad? Also what do you mean static injectors flow a lot of fuel' ? I knew i was running lean (mild-moderate built 350) but i didnt know that bad. Im running 61PPH injectors at (checked FP) 11.5PSI. Waiting to get a AFPR in there with my 65PPH injectors soon.
Engine: LS1 / L03
Ghetto, are you using a vac-ref FPR on that build? also, might want to check your plug gaps after the distri checks out fine. other than that, what's your SA and AFR at cold idle?
edit: sorry just read your last sentence where you state you want to put in an AFPR soon. while you're at it, get a vac-referenced one (VRFPR). prolly want to up fuel pressure to 15 psi, change BPC according to EBL Utility/BPC spreadsheet, and start over with the tune.
I think that's exactly what I'd want to look at. If your fueling has been fine before (not as lean), and suddenly is, I'd suspect one of the fuel system components as the culprit (could be injectors, fuel pump, filter...). You can check fuel pressure with a mech. gauge as well, but want to check it during load as well so you see the pump is still flowing up to par.
, Plus they are the original plugs i put in the motor when i dropped it in 4years ago
(motor has around 25-30k on it)Ive been reading alot on the VRFPRvsAFPR, and just slightly scared on drilling a hole into my manifold for vacuum, ect. Just seems like some work that i could by pass by getting a afpr? Or is the vfpr that much better?
Well the thing is this motor has always been running lean, just never got to see how bad it actually is. Then it sat for 2-1/2 years and now random cold start issues, so im guessing something went bad within that time sitting.
Engine: LS1 / L03
Plugs are your eyes into the engine
Other than that and looking at the exhaust output (oxygen sensor, EGT) there's not a lot we can do to tell what's going on in there. Should put in new ones anyway at that milage too imho.
FPR: depending on how many vac ports you have, you can just tap into one of the existing ones to feed your VRFPR, so I'm not sure where you got the drilling part from. Most VR- or AFPR variants for TBI you can just install instead of the stock fixed FPR in the stock location, so imho that's quite an easy and clean way to do it. Going VRFPR on anything but the cheapest low-perf build is a must imho, and they're not really expensive anyways. As a bandaid you can adjust the stock FPR, but just by a small amount and it's not vacuum referenced, which means depending on your injectors & fuel pressure, you'll end up with your idle too rich or too lean on WOT. Basically, a VRFPR extends your usable injector range quite a bit, because you'll have lower fuel pressure at idle and decel (high vacuum), but more fuel pressure at load and WOT (low vacuum).
Other than that and looking at the exhaust output (oxygen sensor, EGT) there's not a lot we can do to tell what's going on in there. Should put in new ones anyway at that milage too imho.FPR: depending on how many vac ports you have, you can just tap into one of the existing ones to feed your VRFPR, so I'm not sure where you got the drilling part from. Most VR- or AFPR variants for TBI you can just install instead of the stock fixed FPR in the stock location, so imho that's quite an easy and clean way to do it. Going VRFPR on anything but the cheapest low-perf build is a must imho, and they're not really expensive anyways. As a bandaid you can adjust the stock FPR, but just by a small amount and it's not vacuum referenced, which means depending on your injectors & fuel pressure, you'll end up with your idle too rich or too lean on WOT. Basically, a VRFPR extends your usable injector range quite a bit, because you'll have lower fuel pressure at idle and decel (high vacuum), but more fuel pressure at load and WOT (low vacuum).
Only problem with that is you go full throttle when you hit brakes!! LOL.
As Ownor says... However the car just run better all around. I think it works well with AE and transitions overall.
Well i only had time to pull my #1 plug and take a look. I have no knowledge what so ever how to look at a plug, I just know how to look for oil fouling and rich/cold mixture's. heres my number #1, ready to change?
Im glad you said check gapping! This thing was set at .063! i adjusted down to stock setting .035 so we will see, but this now has me thinking towards all of my plugs are gapped incorrectly.
Engine: LS1 / L03
plug not looking too bad imho, brown/tan-ish and no melt-down spots on either center electrode or ground electrode, so not really worn. no oil leaks either. there are about a thousand of pics when you google spark plug chart on how to read them. i'd primarily try to read mixtures/distribution from that, some also read timing stuff from the plugs but myself i haven't done that.
plug shows brown on one side and insulator ceramic white/natural on one side, not sure what that means but i'd guess the brown side is the one closer to the intake valve or the side facing into the chamber.. not sure if that's a problem, but i'd think it should be color all around the insulator tip.
edit: just saw you said gap was .063! much too wide i'd think, although i think a too wide gap would cause a miss at higher loads/speeds. i remember Cflick writing at some point in this thread about plug gaps and their influences on combustion dynamics. only thing that got stuck in my head is this analogy (or fact, even?): a wider gap will allow more air and fuel molecules into the area of the ignition arc, which will help light-off in low load situations (idle, cruise) but might blow out the spark at higher load (WOT, acceleration). vice versa for a too tight gap. i hope i got that right
TPI guys like Kirban. Some say stay away from Holley? TOP DOWN SOLUTIONS sells the spring one step stronger than early stock TBI. The only TBI specific variable A-F FPR I am aware of is Aeromotive and that is what I use. DIVERSIFIED CROSSFIRE SOLUTIONS possible has one as well.
