New to tuning and EBL-P4
Hi all. As stated I am just getting started tuning my Vortec TPI L-98 engine swap in my 86 Caprice Landau. I have the EBL installed using the 3005 bin as recommended by RBob. I need some help setting up the flags etc, I seem to recall a thread that dealt with setting things up but I can't seem to find it. Can anyone point me in the right direction? I did test start the engine yesterday for the first time and it fired on the second crank and idled right down smooth so That battle is won.
Looking forward to getting this engine dialed in as this will be our road trip car.
Thanks in advance for any help or guidance.
Car: check
Engine: check
Transmission: check
Re: New to tuning and EBL-P4
Probably the tuning with EBL thread:
https://www.thirdgen.org/forums/diy-...uning-ebl.html
Can access the calibration help document by:
Start->All Programs->EBL P4 Flash->Calibration Help
RBob.
RBob.
RBob.
RBob.
I have been going down this road for almost a year now (time permitting) and there is a lot to learn. There is no 101 that fits all. Read and re-read RBob tuning 101 articles on his website. Don't try and absorb everything, just where you are. Then read them again b/c you will not understand/absorb all what you read the first time.
There are multiple ways to deal with things so learn and try what you think is best and report your findings here if it is confusing.
You will start with watching BLM and INT. In closed loop they should act predictably. Know what predictably means. If you have *any* old sensors in your car (O2, IAC, TPS, etc) be prepared they are giving you goofy bad readings and tuning will be futile. Know how to test them to make sure they are giving good info to the EBL.
Learn how to record, playback and put EBL into learn mode and save that learn into EBL and see the improvements. EBL is awesome for that.
I have all the 4500 posts in searchable PDF format if you want it. Great for beginners like us.
Check and double check your work, one mistake can drive you crazy.
Check and double check for vac leaks. one can drive you crazy.
And let us know your progress.
Car: 1989 TPI Formula, 1984 MCSS
New to TPI. Some experience with HP Tuners and LS based engines as well as Holley Terminator and 5.0 SBF.
Im just about to pull the trigger on the EBL for my ‘89 TPI Formula.
Quick question on fuel pressure. I installed an adjustable fuel pressure regulator on my TPI and was wondering if I should adjust the pressure with it idling and vacuum hooked up or engine off using fuel pump jumper wire? Right now it has 37.5-38 psi at idle with vacuum hooked up and 43-44 unhooked. I have the regulator backed off all the way and 43-44 is as low as it will go when engine is off. Suggestions? I have the car almost ready to start driving and doing some learns but wanted to get the fuel pressure squared away first.
Thanks, that is what I thought, just wanted to be sure. I just wish the weather was a little cooler. It is hard to get up the ambition to finish it when it is in the high 90's.
Car: 1987 Iroc Vert
Transmission: 5 spd
.[/QUOTE]
Newbie to EBL and I find it confusing, why cant they post a step by step ??. What I have found and tried hasn't worked. Please send me the 4500 posts, hopefully I will get on the right track.
Thank you
.[/QUOTE]
Thank you
RunawayRadio
07-05-2016 11:04 PM
