Pics of stock B4C engines needed!
Old Nov 30, 2006 | 10:22 AM
Jeffrey Fontaine's Avatar
Car: 1992 Z/28
Axle/Gears: 2.73's I think
Hi guys,
I am in need of a new alternator, because when the car runs my lights flicker, but they're fine when its off. I would like to upgrade to a 140 amp alternator, and I prefer to use stock type parts, so no Powermaster etc. I have read in some places that the 91/92 B4C Camaro's came with a 140 amp alternator, but every picture I have ever found online is of the regular CS130 105 amp alternator that every other V8 Camaro got.
Please, someone prove me wrong! I have found the alleged part #'s for alternator and the bracket, but I don't want to waste money on something that won't work because I could not find the source of those part #'s.
Thanks,
Jeff
Old Nov 30, 2006 | 01:26 PM
Andrew89tpi's Avatar
Car: 91 camaro rs
Engine: 350tpi
Maybe you've already seen this link:
http://www.sethirdgen.org/cs144.htm
hope it helps you
Old Nov 30, 2006 | 01:55 PM
Car: 1992 Z/28
I have, but thanks. In re-reading it though, it certainly appears that they never came together stock b/c otherwise it wouldn't take grinding...
I'm wondering if I could make a bracket that wouldn't need grinding...
Old Dec 16, 2006 | 07:09 AM
Bill/T/D/Y's Avatar
Car: 90 R/S camaro 3.1L stock,
Ok myself and a few others are currently doing the alt upgrades and have found alotta info as to where what year make and models have the alts and brkts needed.Do a fast search on my name and the 1 with Me and Vorgath i think pretty much tie in most the links together.Hope this helps.
Old Dec 16, 2006 | 09:59 AM
Car: 1992 Z/28
Yeah I've been lurking over on that thread. I started this before, and to find out if the B4C's ever had this alternator. I read someone "saw" one at a car show on a stock car, but I've never seen a pic.
Old Dec 16, 2006 | 10:26 AM
Bill/T/D/Y's Avatar
Check out
https://www.thirdgen.org/forums/elec...put-cs144.html
For the latest in the drama on the upgrade.
Old Dec 16, 2006 | 04:35 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
You may try finding someplace to rewind the alternator. I took a CS130 to a local alternator shop (DC Engineering here in Bremerton) and had it rewound. They tested the output before returning it at 142 amps (about the max that case can put out). They also added a slightly smaller pulley to maximize the output at idle.
Old Dec 16, 2006 | 04:51 PM
Bill/T/D/Y's Avatar
ok heres a pic of my engine compartment.But postin the rest in the thred in the link above.
Attached Thumbnails Pics of stock B4C engines needed!-engine-compartment.jpg
Azrael91966669
25
Jun 20, 2017 04:04 AM
IROCZ1989
Jan 24, 2016 03:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
