wire color
Re: wire color
If a new electrical connector is needed, they are still available.
Delphi Weather-Pack 3-way Connector with Lock/ CPA.
Delphi part numbers:
-Body =12020829
-Terminals =15344719
-Seals =15324982
-Lock/ CPA =12020833
-Lock/ CPA with Tether =12092054
-Body =12020829
-Seals =15324982
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: wire color
What fuel pump will you be running though? Most have to run new power and ground wires to support the power loads.
Re: wire color
Make sure that any filters used past the Fuel Pumps can handle the Flow of the Fuel Pumps...
Do not use a filter that flows significantly less than the Pumps, it can create a restriction.
2ponchos
04-26-2002 05:04 PM
