'85 140MPH+ SPEEDOMETER?
Car: 1985 & 1991 Trans Ams
Engine: 350 in both
Transmission: Auto in both
Axle/Gears: 3:23 Limited Slip in both
Does anyone know if anyone sells a 140 MPH or higher speedometer for an '85 TA? Thanx!
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Re: '85 140MPH+ SPEEDOMETER?
Not 100% sure but if an 82-84 speedometer will fit the 85 cluster hawks sells an overlay for 140 or 160mph. I've also seen a post on here where someone used a second gen speedometer and those can go to 140mph. There both mechanical so they should work but I'm not sure how different the 85 housing is from pre 85 housings.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
I'm pretty sure that the 140MPH speedo that comes on '86-92 Trans Ams is the same and can fit on the '85 even though as this particular moment I don't recall the '85 having a 140 speedo. Look up on ebay
I just saw one tachometer & a speedo being sold separately and also the whole instrument cluster including gauges being sold. I think the speedo by itself was $99 Here's the link to the whole search results on ebay -->
http://www.ebay.com/sch/sis.html?_nk...d=350493761070
And here's the link to the page for just the 140mph speedo for $99
http://www.ebay.com/itm/86-92-Pontiac-Firebird-Trans-Am-Instrument-Cluster-Speedometer-Gauge-140mph-101K-/321432035513?pt=Motors_Car_Truck_Parts_Accessories&hash=item4ad6d7a0b9
Engine: 350 in both
John in RI is correct, the '86-'92s are electric. I was just hoping that someone by now might have made a repro with 140MPH on it. Thought that I had seen one a while back on ebay. I should have grabbed it. Just disappointing to have a car that will do 140+ but not show it on the speedo. Thanx for the replies!
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
Still looking for one ??
I have one from a 87 trans am 305 tpi
$85 shipped
Dave
Car: 85 Trans Am
Engine: carbed 350 four bolt
Transmission: 700R4 with shift kit
Axle/Gears: 373's
Im trying to do the same thing put a 140mph speedo in my 85TA..... does anyone know if the 82-84 are the same and fit the same and works right???? Anyone done it..... Cant find **** on it everybodys swaping to 87+ clusters
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
Even if you can find an 82-84 speedo, it's not going to match the '85 cluster. 1985 was the only year that still had a cable driven speedometer but with the new gage face pattern. If that isn't a concern, then it might work. I also have an '85 TA and have pondered this dilemma. Hawks does a service where they recalibrate and put a new overlay on your speedo. It's not cheap! The other option is to install an 86-92 cluster and go electronic. For now, I'm stickin' with what I got.
Car: 85 Trans Am
Axle/Gears: 373's
Yea im not to worried to much about it matching perfect from what iv seen it wont look to bad especially with a 140mph in it.. I really just want know how fast im goin I top mine out quik and im sure iv had it past 140mph just pisses me off I dont know how fast u feel me.... I looked at hawks online they had overlays but only white and only for 85mph but it was only $20 thats not to expensive at all considering a new speedo goin to run $75-$175 from what iv seen and u gota change to electric
Car: 85 Trans Am
Axle/Gears: 373's
Thanks for the info man if I find anything else out diffrent il let u know
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
Hawks still has the part I mentioned. You can find it here: http://www.hawksthirdgenparts.com/19...0-speedometer/
I just couldn't justify $249 at the time, and now it's a steal at $199? No thanks. But hey, it's a 160mph cable speedo for 82-84 so it can work in your '85. Oh, did I forget to mention the core charge?
Car: 85 Trans Am
Axle/Gears: 373's
Will they take my speedo for it sense itsdiffrent? ? Iv looked at it already about ten times today alone its price is a little high for me but with $75 off that would put it in my range around $100 hoping to find one for cheaper tho I got a few buddies lookin around for me..... I looked on hawk's they dont have a 140mph overlay for the 85mph they only had 85mph in diffrent colors and that was just white and silver
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
Yes, that is exactly what happens, you send in your 85mph speedo as a "core". They recalibrate it and put a new overlay on and send it back to you. Essentially you're getting your speedo back. It occurs to me that most speedometer shops can do this. If you have one near you, they may be able to do the same thing for less. It wouldn't hurt to do a little searching in your area.
Car: 85 Trans Am
Axle/Gears: 373's
I see mybad thought it had to be a Speedo from the same year for the core... iv seen a few places on here people are sayin will do it looks like I might have to start making some calls see what shops are charging for it... thanks for the help man im gettin a better idea of what my options are
Elephantismo
Feb 13, 2019 12:51 AM
