5.3 Accessories
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
5.3 Accessories
I am receiving my 2006 5.3 vortec at the end of this month, I've been doing a TON of searching on here and found about 90% of the info I needed to know. I do have one question about the choice of accessory drives, I know I will have to go with F-body accessories but I found an accessory drive kit that GM sells. The part number for this kit is #19155066
It includes:
12578548 Bracket-Air Conditioning
89023451 Compressor-Air Conditioning
12595289 Tensioner-Air Conditioning Belt
12578549 Belt-Air Conditioning Compressor
12578551 Bracket-Power Steering Pump
21997867 Pump-Power Steering
12578552 Pulley-Power Steering Pump
21997866 Reservoir-Power Steering Pump
21997868 Hose_Power Steering Fluid Reservoir With Clamps
12578550 Bracket-Generator
25766345 Generator
12568996 Pulley-Belt Idler
12569301 Tensioner-Drive Idler
12578553 Belt-Water Pump/Generator/Power Steering
All for a little over $700 on GMPartsdirect.com
I cannot post pics of the accessory drive right now because i'm at work but if you go to crateenginedepot.com and type that part number in, it will show you a picture. It says it's a CTS-V design but it looks just like the f-body setup, does anyone know if this will work?
Thanks, Dan
It includes:
25766345 Generator
Thanks, Dan
Car: 1971 Corvette
Engine: 6.0 LS1 L92 heads sheet metal etc.
Transmission: M21 4-speed
Axle/Gears: 3.36
Re: 5.3 Accessories
The truck stuff will work, you just have to notch the inner structure of the hood for the alternator.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 5.3 Accessories
Dunno if this applies to you, but GM just released 2 more versions of that, only without the A/C stuff. Saves a couple hundred dollars.
Engine: LSx 5.3
Re: 5.3 Accessories
Here's the pic of the accessories
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Re: 5.3 Accessories
Engine: LSx 5.3
Re: 5.3 Accessories
Yeah I was thinking about buying that kit, seems like by the time you buy th ps pump, a/c compressor, and alternator, it adds up to the same kit you can buy from gm that comes with all of these. Idk i'll do some research.
Thanks for the help everyone! Dan
Car: 1971 Corvette
Axle/Gears: 3.36
Re: 5.3 Accessories
Heh - actually no. Not unless you're looking at some vastly different "truck stuff" than what I've been working with...
Engine: LSx 5.3
Re: 5.3 Accessories
Does anyone have any info on what size drill bit and tap I need for the alternator bracket?
Thanks, Dan
Thanks, Dan
ZZ3Astro
08-13-2019 12:57 AM
355tpipickup
09-28-2015 05:50 PM
12578550, 12578552, 19155066, 21997867, 53, accessories, alternator, bolt, bracketgenerator, fbody, gm, pulleyps, pump, size, tap
