Ohio?
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
Re: Ohio?
I hate to be a dick............but.......well lol.
Ninetyone just PM'd me this:
"Hey bro, I apologize. I didn't mean to come across that way. No hard feelings"
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
Re: Ohio?
someday i just might, when i can financially do so lol, how much does it cost to show up and make a few passes? no helmet needed?
Engine: 355
Transmission: 4L60
Engine: 355
Transmission: 4L60
Transmission: 5spd
Re: Ohio?
thats not bad, that and gas to get there i should be able to sometime when it gets warm again, probably spring, have to wait till everyones heading out so i could get some input on my car
Engine: 355
Transmission: 4L60
Re: Ohio?
Yeah, they are all closed for the season anyway. Should be open in April. I have some work to do to my car anyway and some mods, so it is pretty much down for the winter.
Transmission: 5spd
Re: Ohio?
yeah, i quite frequently make an *** of myself on here, but as soon as i saw a video and a timeslip i'd of just said that i'd been proved wrong, then i'd of asked your input on how to get my car that fast (given he had an l98)
Transmission: 5spd
Engine: 355
Transmission: 4L60
Re: Ohio?
Exactly. Instead of continuing being a dick, just be a man and say you were wrong, and take it from there.
Engine: 355
Transmission: 4L60
Re: Ohio?
Gonna depend on money. Probably a direct port nitrous kit I found for sale, a set of modded 113 heads, and a ZZ4 cam with 1.6 ratio full rockers. Also some chassis and tranny mods to support it. Should put me into low 12's/high 11's.
Transmission: 5spd
Re: Ohio?
sounds tasty, and can i say you have a very nice car, never seen one like that, with those wheels/color/tailights/spoiler
Engine: 355
Transmission: 4L60
Re: Ohio?
Engine: 355
Transmission: 4L60
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
Engine: 355
Transmission: 4L60
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: Ohio?
Im just going to get a transgo shift kit for one till I can either afford a TH350 swap or figure out what im going to do otherwise.
Engine: 355
Transmission: 4L60
Re: Ohio?
Somebody needs to take this damn diff off my hands. My mom fell over it last night after dinner, and she was already hurt to begin with. I have nowhere to put the stupid thing.
Car: 1991 Camaro RS
Engine: 408 LS
Re: Ohio?
Car: 1991 camaro rs
Engine: twin turbo 406
Transmission: th400 w/brake 4400 stall
Axle/Gears: 3.42s
Car: 1991 Camaro RS
Re: Ohio?
You V8 guys..lol. My 700R4 has a horrible aftermarket comparted to yours. Thats why Im thinking or debating swaping it out. Mainly my TC aftermarket suxs, since thats a major thing that differes from my narrow 700r4 and your normal 700r4.
Its a easy swap just dont have the funds for it at the moment. And they are a little stronger then the 700R4 but thats not the reason as I will only be pushing 300Hp or so and last year my stock 700R didnt break with Hp like that. So im either lucky or the 700 will handle a little bit.
Did I mention transbrake...lmao
Re: Ohio?
Car: 1991 Camaro RS
Re: Ohio?
I know dave. Im getting a set of real slicks next spring from a racing buddy. Hes going to a 28 inch tire so im getting his. There 26x8.5x15 inch slicks. Only 2 seasons on them and the tread wear holes are good as gold still. They will do much better. Mickey-t's again. The trans brake was just a joke though, i dont have the cash to shell out and make sure everything holds together..lol
Re: Ohio?
i had trouble with my 26x9's and anything more then 3-4 psi of boost
once i went to 28x10.5 W's i had no more issues
then again ur 3:73's arent going to hit the tires as hard as my 4:11's
Car: 1991 Camaro RS
Re: Ohio?
you had 4.11's?? Yea I bet that hit hard off the line dave.
Re: Ohio?
Yup they were in the car from my n/a build so i just left them in they hurt me on the backhalf of the track but from line to 1/8th they worked great.its also what allowed me to get 1.7-1.8x 60's only launching with 3-4psi
car would prolly drop 2-4 tenths in the 1/4 just by swaping to 3:42's or 3:73's
u pick up about 4-6 more mph on the backhalf then my car ever did
Car: 1991 camaro RS
Re: Ohio?
budfreak the 1.6 rockers wont fit 113 heads on the exhaust side with the zz3 cam
the gears are 3.23 bud? and working posi? im in the middle of debateing to swap to 2.73s or 3.08s for better fuel mileage and the
and to save the tires a bit on take off lol but also a working posi would be nice again
Engine: 355
Transmission: 4L60
Re: Ohio?
Yep, 3.23/posi/drums/28 spline.
Car: 1991 camaro RS
Re: Ohio?
the lift will be to high for both springs and valve guides i would have installed my 1.6 roller rockers in my zz3 if i could have i could install 1.6 intake 1.5 exhaust
what was going wrong with the rear bad wheel bearing? or bad axle honestly
id most likely be scraping the housing just use the posi in my disc axle
Engine: 355
Transmission: 4L60
Re: Ohio?
And I know about the springs, I wouldn't use stock ones.
Have no idea, never tore it apart. Was just making a whirring sound, like a bearing failing.
Car: 1991 camaro RS
Re: Ohio?
all the info i found told me .530ish lift was max mind you running 1.6 and 1.5 puts the cam at 510 510 i thought about doing that
i also did test the 1.6 on the exhaust and i couldnt even get the engine to turn over by hand when i had it on the stand so i assumed it was coil bind and i didnt want to attempt it so i left the factory ones in till i get 1.5s
Engine: 355
Transmission: 4L60
Re: Ohio?
Car: 1991 Camaro RS
Re: Ohio?
Id go to 42 I I was you as youll get massive time trials. The tracks rough but I will say its a fun track to just make some passes if you never have before. No helment unless your constantly going fast (13.99 and under at norwalk) But to be honest if your going that fast why not wear a helment...
Re: Ohio?
going to a lower gear will not always save gas. it depends on were u do most of ur driving city vs highway
lower gears will lower mpg in stop and go traffic as u need to use more throttle to get the car moving and upto speed in stop and go traffic
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
Re: Ohio?
All the goodies I got from Summit on Black Friday. Total cost was over $1000 lol.
Car: 1991 Camaro RS
Engine: 355
Transmission: 4L60
Re: Ohio?
Engine: 355
Transmission: 4L60
Re: Ohio?
Man, that 91 dude is the biggest $*$*^$^&$*%^#*%^$)*^&_)(*_&%&$ RETARD I have EVER met. I can't even find words to describe the amount of disgust I have with people like him. No knowledge, no idea how **** works, just goes by what he learned from one shitty car that they didn't even build right and couldn't drive, then takes it as facts and nobody could possibly be right but them or outrun them, then they spew there false crap all over the internet.
It's people like that who I'd just like to smash their ****in faces in with a brick.
Engine: 408 LS
Re: Ohio?
Engine: 355
Transmission: 4L60
Engine: 355
Transmission: 4L60
