Hmmm, what should I do? the headers are melting the solder on my battery cable?
Old Feb 19, 2001 | 03:49 PM
crazeinc's Avatar
The subject pretty much says it all. I couldn't figure out why my car wasn't starting and then I yanked on the cable and it came right out of the connector. I haven't had any luck crimping it and solder was my solution. Unfortunately, that's not going to work here. What do I do??
1982 Camaro Z28
should be running 11's this spring...we'll see
Check the website for progress http://members.fbody.com/Pro82Z/
Old Feb 19, 2001 | 04:00 PM
Blockhead's Avatar
Theres uh something wrong.. with my batt ery. Who ya gonna call. GHOSTBUSTERS!
uh you could try getting a new battery cable...
89RS w/ Powerhouse 334 stroker
Director of Darwin Awards @ www.thirdgen.org
[This message has been edited by Blockhead (edited February 19, 2001).]
Old Feb 19, 2001 | 04:09 PM
crazeinc's Avatar
stop wasting everyone's time on these boards...go away...the battery cable came customizable you dumbass.
Old Feb 19, 2001 | 05:16 PM
novadude's Avatar
Here is what you do:
1. Measure length of cable
2. Go to local Autozone
3. Find cable that is proper lentgth
4. Plop $10 down on counter
5. Go home & install
Problem solved!
Old Feb 20, 2001 | 12:43 AM
Conv389drv's Avatar
Okay, how about a serious suggestion:
Heat shield!!
Either wrap the cable with something or get creative with sheet metal. Just a suggestion off the top of my head. Good luck!!
Old Feb 20, 2001 | 07:16 AM
Blockhead's Avatar
I wasnt lying! Go buy a new battery cable!! **** man i stripped the bolt on my side post cables once and just went and bought a new cable at auto zone.
have a sense of humor.
Old Feb 20, 2001 | 07:24 AM
Biochem's Avatar
Car: 2002 SOM z28
<font face="Verdana, Arial" size="2">Originally posted by Conv389drv:
Heat shield!!
</font>
Am I missing the point? Customizable cable? How special can a 2 gauge wire from the positive terminal to the starter be? A heat shield will not really help any (if you have ever installed one and if I am understanding what you are asking...).
Cables are cheap and easy to find in all sorts of sizes and attachments.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Feb 20, 2001 | 08:21 AM
The ODB's Avatar
Take your old cable to a good battery shop. They will make you a much better quality piece out of welding cable and crimp the terminals on in a way that will not come loose.
Heat is always bad for wires and electronics. I use heat shielding on my own cars for both wires/starter and the exhaust.
Welding cable is high quality copper with hundreds of strands versus a 10-20 for the auto-zone version. The welding cable will pass much more current.
good luck
ODB
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
andy74
Sep 3, 2015 08:41 AM
