TRANS leaking help!!!!
Old Jun 12, 2025 | 06:13 PM
ThatZ28's Avatar
Engine: 355
Transmission: Th200c
my transmission is leaking from the part where than pan and dipstick tube connects, please advise on what parts needed to fix and how to….desperately losing fluid all over shop!
File Type: mov
Old Jun 12, 2025 | 06:28 PM
tbroadfoot125's Avatar
Engine: 87 5.0L TPI
Re: TRANS leaking help!!!!
On the 700R4 transmission there is either a boot seal or a O ring. Available at most parts stores
Old Jun 12, 2025 | 06:34 PM
ThatZ28's Avatar
Engine: 355
is it a 700r4 trans??? It’s an 82 z28
Old Jun 13, 2025 | 09:20 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Probably an o-ring. Had same problem on a th350 & replaced the o-ring.
Old Jun 13, 2025 | 06:52 PM
Engine: 87 5.0L TPI
The 82 Z28 had 2 options for the transmission, manual or automatic (700R4). Since you have a dipstick, its the 700R4. Check with your local parts store they should have the dipstick tube seal or even rock auto.
Old Jun 13, 2025 | 07:40 PM
Mikos_89's Avatar
Car: '89 GTA, '15 Camaro LS 6sp.
Engine: L98, LFX.
Transmission: 4L60, AY6.
Axle/Gears: 3.27's.
It looks like your dipstick tube seal has been lifted out of the case and split as well. The dip stick tube seal needs to be replaced. Loosen the bolt that secures the dip stick bracket and lift up to replace the seal. Might be tight clearance the way the tube bends going up the back of the engine. But I think you should be fine without having to lower the trans to gain more clearance.
Old Jun 13, 2025 | 07:46 PM
ThatZ28's Avatar
Engine: 355
thank you all for the help it was the dipstick tube and grommet I fixed that for about $15 but it’s still leak from about 2 inches on the left where the pan bolts to the trans only leaks when I fill up more then I wanna say about 6-7 qt is it my pan or deeper problem?
Old Jun 13, 2025 | 07:59 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
I suggest you clean the immediate area and then LOOK carefully for the leak. Asking people on the internet to pinpoint your precise leak location is like asking Tiger Woods to fix your golf swing over the phone.
Old Jun 13, 2025 | 08:01 PM
ThatZ28's Avatar
Engine: 355
yes i agree I have done that just looking around for another opinions as this is my first time every working on this time of transmission or this car in general that being said i pretty sure the previous owner over tightened that bolt there causing it to warp
Old Jun 13, 2025 | 09:54 PM
Mikos_89's Avatar
Engine: L98, LFX.
Axle/Gears: 3.27's.
If the pan is leaking from that area, then you may need to replace the pan gasket too. When you have the pan off, you can place it on something flat and level to see if it got bent or not.
Old Jun 13, 2025 | 10:11 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
'Probably doesn't matter, but the 700R-4 wasn't available until '83.
The transmission is likely 200C (if original)...
Old Jun 14, 2025 | 04:01 PM
Pro Built Automatics's Avatar
It is obvious from the photo that the "top hat" seal is broken and protruding from the case. The dipstick tube will have to be removed and thoroughly cleaned up. Where the seal goes into the transmission. Make sure that area is cleaned up also. Put a little on the seal before installing it in the case. Put a little oil on the tube where it goes into the seal in the case. That way you will not tear anything up on the installation.
WaaX
Dec 25, 2006 12:32 PM
fast83ta
Jan 25, 2006 02:59 PM
Strokeme
Jan 27, 2004 03:36 PM
92RS shearn
Sep 20, 2003 10:21 PM
zee28
Feb 17, 2002 02:15 PM
