Turbo Install
Old Feb 10, 2012 | 05:24 PM
  #401
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: Purge can/ turbo...install
Originally Posted by Street Lethal
147 BLM is lean, not rich, you said your idle was reading a rich BLM. See below...
It would go up and down... at one point the blm was 110 then would shoot up to 150. the ints were directly oppisite of the blms.
Old Feb 10, 2012 | 05:26 PM
  #402
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by fasteddi
It would go up and down... at one point the blm was 110 then would shoot up to 150. the ints were directly oppisite of the blms....
INT will add or subtract to the current BLM value to move the INT average towards 128. If the BLM reaches a limit, the ECM is still able to keep the engine averaging stoichiometric so long as the INT is not at its' limit. You more than likely did have a vacuum leak...
Old Feb 10, 2012 | 05:27 PM
  #403
Six_Shooter's Avatar
Transmission: 5-speed/T-5
To clear it up..what is the best route to see that the NB is working right??? I need to make sure thats not messin up my fueling through the ecu. There is no codes thrown on datalogging
As long as you've forced open loop (setting coolant temp to enable CL at max will do this), then the NB won't be causing any fuel trimming.
I'll have to test, but I think grounding the NB O2 wire will at least show a change on the datalog to test the wiring and ECM functionality itself. I'll test this later on my test bench and get back to you.
I've tested for functionality of feedback by simply over or under fueling the engine and watching for a change, but I wouldn't recommend this at this point.
If the NBO2 is a heated type you can turn the ignition on and let it warm up, and after it's warm should show a lean condition, usually very low voltage, say around .08 to .12 mV, with the engine not started, just a heated O2.
Old Feb 10, 2012 | 05:29 PM
  #404
fasteddi's Avatar
Car: 1991 Camaro RS
I found one(vac leak) at one point and fixed it then started from scratch tuning....Let me look at the logs again becasue the one im talking about might have been before i found that leak.....I was just looking at old logs
opps forget those numbers... i was reading 125-135Blms at idle. I was looking at the wrong log before.. But as I look the o2 reading was .335-.355 at idle with those blm's
Old Feb 10, 2012 | 05:34 PM
  #405
Remember, so long as the INT is able to maintain stoich in the combustion chambers, the narrowband reading remains the byproduct of that average. So even though your BLM was reading either too lean or too rich, the INT kept the engine running stoichiometric, which is why you were showing a high or low BLM but w/correct narrowband reading. That just tells you that the INT is doing its' job properly. Your narrowband is fine...
Old Feb 10, 2012 | 05:35 PM
  #406
opps forget those numbers... i was reading 125-135Blms at idle. I was looking at the wrong log before.. But as I look the o2 reading was .335-.355 at idle with those blm's...
But where was your INT during those BLM readings though, as that would have effected the narrowband reading as well. The two go hand in hand, one is long term fuel adjustment, and the other is short term fuel adjustment...
Old Feb 10, 2012 | 05:36 PM
  #407
project89's Avatar
his narrow band isnt going to read correctly at all if he moved it, it wont heat up enough
were did u mount the nb o2 anyways did u put it in the upipe to the turbo?
Old Feb 10, 2012 | 05:38 PM
  #408
fasteddi's Avatar
Car: 1991 Camaro RS
Its about 1 foot from where the pipe went off the y pipe to the turbo.. its about 4 inches from where the 90* pipe starts on the up pipe
The most stable numbers from the $88 tune was .390mv NB and 130INT 132BLM at idle
Old Feb 10, 2012 | 05:40 PM
  #409
The most stable numbers from the $88 tune was .390mv NB and 130INT 132BLM at idle...
A .390mv is a tad above 14.7 air/fuel ratio, that is a perfect reading. You narrowband is fine...
Old Feb 10, 2012 | 05:45 PM
  #410
fasteddi's Avatar
Car: 1991 Camaro RS
What about this placement of the narrow band??? The new mask i have doent have the Cat, temp on it so i have no idea how hot that NB is.... Its not a heated one
Old Feb 10, 2012 | 06:33 PM
  #411
fasteddi's Avatar
Car: 1991 Camaro RS
Ok well heres the plan for tommorow if i get time... The timing is 20* at idle. It was sig. higher when i used the $88 mask. It was 24* at idle when i finally got a good idle tune.
So fix my lil oil leak, and see if i can hook the simulated NB into the ECU.. I really think that my NB isnt getting hot enough or something as its stagnit at .450 even when i rev the motor up, its like it never moves much more then .030mv ever!
And if i can get the simulated NB working correctly then Ill tune from there and if I get into having afrs of 14-15 and it hunts at idle again Ill add timing and see if that works out.
I did get the blow off valve adapter so ill do that also, as its snowing now, theyll be no driving the car for a little bit....
Old Feb 10, 2012 | 08:14 PM
  #412
project89's Avatar
a steady .450 mv means the 02 is not hot enough, and it wont get hot enough unless ur cruising down the road in that location, thats why i had to goto a heated 02 sensor on my car. since u have the wideband dont even waste the money on one.
hookup the simulated nb output or setup the ecm for the wideband input
Old Feb 10, 2012 | 08:30 PM
  #413
fasteddi's Avatar
Car: 1991 Camaro RS
Ok dave that makes perfect sence as to why its just stuck at .450 or so. Ill get on that tommorow. Thanks!
Old Feb 10, 2012 | 09:35 PM
  #414
a steady .450 mv means the 02 is not hot enough...
That isn't true at all. A steady .450mv indicates an open 02 sensor circuit, or a faulty 02 signal ground. It is definitely getting hot enough, you just may have a bad sensor though, Mark...
Old Feb 10, 2012 | 09:44 PM
  #415
fasteddi's Avatar
Car: 1991 Camaro RS
Well either way, since this controler can output a simulated narrowband too, ill just hook that into the ECU pin tommorow. And see what happends.
Anyone happend to know off there head which pin the narrowband o2 sensor goes on the ecu?
Old Feb 10, 2012 | 10:00 PM
  #416
E14
Old Feb 10, 2012 | 10:03 PM
  #417
fasteddi's Avatar
Car: 1991 Camaro RS
Ok E14 for the narrow input and im thinking that F14 will be the linear WB input. But ill focus on doing the NB first
My mask has alot of linear input flags but there is no SLC one. But they all have these values. Are these basically all the same?
(Volts*2) + 10
Old Feb 10, 2012 | 10:04 PM
  #418
project89's Avatar
rob its not hot enough plain and simple been there done that got the tshirt
Old Feb 10, 2012 | 10:13 PM
  #419
Been there done that lmao? Constant .450mv (bias voltage) indicates an open circuit or bad ground, end of story. But despite that, why would you suggest it is not getting hot enough without first testing it with an oscilliscope? Your wrong Dave...
Old Feb 10, 2012 | 10:15 PM
  #420
fasteddi's Avatar
Car: 1991 Camaro RS
I think we should change this thread to the argument thread
Old Feb 10, 2012 | 10:25 PM
  #421
Nobody is arguing, I am surrounded by XFI and '7148 Turbo Tweak users all day long running every possible turbo configuration you can think of, and these discussions take place every single day. These discussions will only help you in the end because it will help you to narrow down your tune...
Old Feb 10, 2012 | 10:28 PM
  #422
project89's Avatar
until an o2 sensor is at operating temp the voltage on the o2 line will be .450 mv period
stick an o2 sensor in a bench vise then hook a voltmeter ground to the body and the positive leed on the signal wire and start to heat the o2 up u will see .450 mv untill the o2 sensor is hot enough and then it will go up or down depending were u have the flame from the torch. but until it reaches it operating temp the voltage will not change from .450
do the same thing with a heated 02 but without the torch just hook the heater to 12 volts and hook up the heater ground and watch the voltage on a volt meter it does the same exact thing
and the point is anytime u move the o2 location further down the y-pipe on one of these v6 motors is it will not reach operating temp
he has a single wire o2 if it was not hooked up the datalog would show 0 voltage period
Old Feb 10, 2012 | 10:40 PM
  #423
until an o2 sensor is at operating temp the voltage on the o2 line will be .450 mv period...
Irrelevant, you do not know what his 02 sensor is reading in terms of temperature, that is an assumption. Bias voltage is set at .450mv, and that is an indication of a defective 02 sensor. Do you think it is just a coincidence that the engine is running smooth with the narrowband at stoich, and running rough with the wideband running stoich? Try again...
stick an o2 sensor in a bench...
Dude, you can stick an 02 sensor up your butt and it still doesn't change the fact that your making an assumption without even seeing what his EGT's are reading, not to mention aren't testing the 02 with an oscilliscope. Your making a suggestion that the 02 isn't getting hot enough, but that doesn't mean that is the correct suggestion...
do the same thing with a heated 02 but without the torch just hook the heater to 12 volts and hook up the heater ground and watch the voltage on a volt meter it does the same exact thing...
Heated 02 sensors do not rely on exhaust temperature, they are self heating, and to correlate them with a non-heated sensor makes absolutely no sense. Not to mention, applying 12 volts will "heat" the heated 02 sensor, and if it does the same thing as the non-heated sensor when it is heated, then you are insinuating that the 02 is in fact getting hot enough. What exactly are you saying...?
and the point is anytime u move the o2 location further down the y-pipe on one of these v6 motors is it will not reach operating temp...
Further down? How much further down did he move it? A narrowband 02 sensor placed either before the turbo, or in the turbo's downpipe, will get much more hotter than it would in a non turbo application being left in the stock location...
he has a single wire o2 if it was not hooked up the datalog would show 0 voltage period...
Not hooked up, what are you smoking? .450mv is bias voltage, and if it was not hooked up and if it was reading "0" voltage he would be stuck in Open Loop, try again...
Old Feb 10, 2012 | 10:47 PM
  #424
project89's Avatar
im done ive already had this issue has have a few others with v6's on this board, fast i already gave u the soulution
if u didnt have a wideband a heated o2 in the downpipe would be the fix
Old Feb 10, 2012 | 10:49 PM
  #425
Get over yourself my friend...
Old Feb 11, 2012 | 07:03 AM
  #426
fasteddi's Avatar
Car: 1991 Camaro RS
Rob i was just jokeing man.
It really cold out, like 15 degrees so I dont know what ill get accomplished in the garage as the heater in there can only do so much. But ill get the simulated NB hooked up and well see what happends!
Not to take sides but before when logging, if i just let it idle for 10 minuets, it would never go into closed loop when it was somewhat cold outside(>40 degrees out) The only time it would go into closed loop is when i started driving it down the road. And since I never drove the car yet, I cant say for sure that it is hot enough. No I havent measured EGT, but I think that either the NB sensor is bad or the temp isnt getting high enough just sitting at idle. So ill fix that and just use the simulated NB.
Old Feb 11, 2012 | 08:10 AM
  #427
Not to take sides but before when logging, if i just let it idle for 10 minuets, it would never go into closed loop when it was somewhat cold outside(>40 degrees out) The only time it would go into closed loop is when i started driving it down the road. And since I never drove the car yet, I cant say for sure that it is hot enough. No I havent measured EGT, but I think that either the NB sensor is bad or the temp isnt getting high enough just sitting at idle. So ill fix that and just use the simulated NB...
I said above that if your narrow band is reading .450mv constantly then there is a problem with the sensor, not that it isn't getting hot enough, but a problem with the sensor. You yourself said you had the same problem with that narrowband with your naturally aspirated setup running the $88 mask, which only pushes to a bad sensor even more, not a cold sensor. Also, you said your $59 code was setup to run Open Loop, correct? Did you alter the bin so that it will be able to reach Closed Loop? When 02 sensors reach about 600 degrees they will begin to read accurately, and the average temperature for combustion is 1600 degrees. When is Closed Loop enabled in your bin? What coolant temperature triggers it? Understand that just because an 02 sensor isn't getting hot enough does not mean that the engine is stuck in Open Loop because of it. Open Loop = Open Circuit, so unless the 02 sensor is disconnected (Open Circuit) it isn't causing Open Loop. If your stuck in Open Loop because of the weather I would look into your engine temperature. Are you running a thermostat? What temperature, 160? ECM's going back and forth into Open Loop and Closed Loop because of engine temperature is very common. A cold 02 sensor causes skewed data, not Open Loop. Only a disconnected 02 sensor causes Open Loop, or a malfunctioning one due to a open circuit or a bad ground...
Old Feb 11, 2012 | 08:24 AM
  #428
Please clarify what coolant temperature triggers Closed Loop in your $59 bin, then clarify what temperature your fan(s) are triggered to come on, as well as what thermostat you are running...
Old Feb 11, 2012 | 09:09 AM
  #429
Mark, I would like nothing more for it to be a cold 02 sensor causing your problems, as all it would then take is moving it closer towards the turbine on the downpipe, either that or putting it back in the stock location. For what it is worth, this is how cold starting works. When we start the engine cold, the ECM will keep the engine running based on predetermined coolant temperature readings until Closed Loop is enabled. What enables Closed Loop? The ECM waits for the correct coolant temperature to be reached, there is also a timer programmed in the memcal, as well varying output voltage from the 02 sensor. The first two are obvious, however with the 02 sensor, it only takes 300 degrees to tell the ECM that it is ready for business, and 600 degrees for the information being sent to be all the more accurate. You would of had to of installed the 02 sensor all the way back by the catalytic converter for it to not reach 300 degrees, in fact, I would go even further to suggest that it would have to be even further than the catalytic converter to be colder than 300 degrees because the minimum temperature at which a catalytic converter begins to function (light-off temperature), is 600-700 degrees. Again, I do not feel that your 02 sensor is not getting hot enough, because it should be. If anything, it is bad. That is all I am going to say about that...
Old Feb 11, 2012 | 10:44 AM
  #430
fasteddi's Avatar
Car: 1991 Camaro RS
My enable close loop is set at 151*c. It was like that from the starter bin, I left it that way as Im told from many($59 users) To tune in closed loop you need to work on the open loop first or youll be chasing you tail for awhile. Exspecially since the linear input on the ADX is there and avalible to tune VE tables.
The thermostat is a 180* one. I cycle the fan myself @ 200* if it gets there.
I did manage to get the BOV installed, ran the Vac line to the manifold.
Also some idiot(I wont mention names) forgot to tighten down the oil return line fitting at the turbo..that was causing the oil leak I was talking about yesterday.
So I am going to go do the f6-f4 pinout for the TCC and also wire in the simulated NB on the E14 and the linear one the F14. Then ill start the car up for a few just to see if the values all read correct and that the oil leak has stopped.
Old Feb 11, 2012 | 10:49 AM
  #431
My enable close loop is set at 151*c....
That is of course why you are not seeing Closed Loop, 151*C is 304*F...
  #432
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
street lethal, you "proved" that is nb was fine. now you're convinced its bad. make up your mind! You're info goes back and forth too much. Mark, (no offense street lethal) I'd listen to Dave or Rbob more! Sounds like you're on the right track. good luck with it!
Old Feb 11, 2012 | 10:52 AM
  #433
Car: 91 Camaro
also, how many times does mark have to point out that it is force open loop. he's not trying to go into closed loop, from what I'm seeing.
Old Feb 11, 2012 | 11:12 AM
  #434
fasteddi's Avatar
Car: 1991 Camaro RS
Yea I definitly know im in open loop only. I dont want to be in closed loop, untill I get the AFR's in check.
Old Feb 11, 2012 | 11:32 AM
  #435
No offense taken, why would I be offended with someone who does not know how to read lol? I said the narrowband is fine in terms of being EXHAUST HEATED, nobody is saying that it is "functional" though because of the constant .450mv, if you carefully read what I said instead of spewing nonsense you would see that I pointed out that the 02 sensor itself was suspect if it maintains .450mv due to an open circuit or bad ground in the sensor, not that it wasn't getting heated by the exhuast, but that it might be a bad sensor in itself. The narrowband is obviously not causing Open Loop due to it not getting hot enough, his Closed Loop enable setting in the bin is, that was just to clear the air about Closed Loop because he stated that he was having a similar problem with his narrowband with the $88. That was the argument, so buy yourself a clue. As for listening to RBob, I invited RBob to this thread already through PM a week ago, as well as suggested his EBL before he even got into burning chips. So, I appreciate your little rant, but if you cannot suggest anything useful in terms of helping Mark to figure out his problem, then why say anything? His engine stalls at 14.7 using the wideband, so I suggested changing the spark reference in his $59 bin to match his 3.1 setting because I believe the $58 bin is set to "0", but nobody commented about that. Aside from that, he cannot idle with the wideband reading stoich, let alone anything leaner than that. So, what do you think it is, AM91Camaro_RS...?
Old Feb 11, 2012 | 11:44 AM
  #436
Mark, my whole entire argument was for you to allow the engine to run in Closed Loop to visually see what your narrowband is reading, and try to correlate that reading with your new wideband sensor. You need to first make sure your wideband is reading correctly before you tune with it. If you trigger Closed Loop by lowering the coolant temp target, allow the 02 sensor to adjust long and short term correction to see where your BLM is, and get a feel for how the engine is running by getting it as close to 128-BLM as possible, then correlate your wideband reading with what your BLM's are reading. That was my whole entire argument. As said, I purchased an LM1 as my first wideband years ago and it was giving me the wrong air/fuel reading right out of the box, and I wouldn't have known that had I didn't compare it. If I didn't compare that reading with my BLM, I would have been tuning with it being a full point richer. That is what I was saying...
Old Feb 11, 2012 | 01:21 PM
  #437
Car: 91 Camaro
I suspect the timing, also. I bet it'll go into closed loop (once allowed!) when he can drive it. All things considered, as they are, including outside temps I imagine the nb sensor is ok. I'm no expert at tuning, by any means. I'm not claiming to be. But, I have dabled in it, a little. I've read lots of things that Rbob (and others) have posted and his stuff just makes sense... I've been doing lots of reading in this thread because there is lots of good info. There's also lots of useless crap.
Old Feb 11, 2012 | 01:52 PM
  #438
fasteddi's Avatar
Car: 1991 Camaro RS
Ok well i got the wires all done and now the WB and NB match. Also I can read out the AFR with the ADX file i have.
I got the car to run well at about 13-14 AFR. Any higher and it hunts, even if i add timing. Doesnt the colder Intake temps play any effect as the engine temp was 180 but the Intake temps never got higher then 50*.
And just to goof arround i did give it a little gas in drive just in the garage, carfully looking at the spark retard/knock and the AFR...WTF is that blow off valve loud and so it the turbo. I just did it once and dont worrie i wasnt getting on it too hard, the AFRs were at about 11 flat when i did spool the turbo up. Just wanted to make sure the turbo worked...
Old Feb 11, 2012 | 02:12 PM
  #439
Ok well i got the wires all done and now the WB and NB match. Also I can read out the AFR with the ADX file i have...
Good!
I got the car to run well at about 13-14 AFR. Any higher and it hunts, even if i add timing. Doesnt the colder Intake temps play any effect as the engine temp was 180 but the Intake temps never got higher then 50*....
From what I have been reading about the $59 code, because I have never ran that bin before and I can only go by what others who have ran it are syaing, many people experience that very issue. They can get the idle to be very smooth in the 13-14 range, but once they lean it out to the 14-15 it will hunt. This is only without a load, as during a load they can get it to idle well in the 14-15 range at low RPM...
Where is your base timing set, Mark...?
Old Feb 11, 2012 | 02:30 PM
  #440
project89's Avatar
u do relize this now requires a video right :P
Old Feb 11, 2012 | 02:31 PM
  #441
RBob's Avatar
Car: check
Engine: check
Transmission: check
Kinda' makes one wonder if the injector PW is getting small and the ECM is switching to quasi-async mode...
The status is in the stock $58 code data stream.
RBob.
Old Feb 11, 2012 | 02:48 PM
  #442
RBob.
Bob, this is what puzzles me when members who run $59 say that they run a 15+ air/fuel ratio when quasi fuel is so horrible to begin with. I think this is what Steve's (ZZ3astro) problem was all along before he went Megasquirt, he was trying to run a lean air/fuel ratio with $59 in conjunction with injectors that were losing ohms (dropping from 12 to 8.8), and it was hunting horribly. Even the writer of $59 admits that the code is essentially an expanded $58 code, and encourages everyone to disable quasi fuel. I just ran a quick search, and this is what he explains, so perhaps give it a try Mark...
QUASI-ASYNCH MPH THRESHOLD (KQSYNMPH) - I think you Set this to 255 MPH to disable but this also affects the transition from quasi to sync. So you want to make sure quasi never comes on.
RPM above which Quasi-Asynch Fuel is NOT USED (KQASRPMD) - Set this to 0 RPM to keep it in SYNC mode most of the time as long as your pulse never goes below KAPLL
Next lower MIN Base Pulse (KAPLL) to 0 so it will never go Quasi.
In the 59 XDF, I labeled all the items with the Variable that is in the P4 Document. So it makes it easier to follow the P4 Doc. Here is what is says about Enabling Conditions for Sync. Pulse.
9.2.1.1 Synchronous Fuel Enable Criteria
The synchronous fuel delivery mode will be enabled when ignition is ON, and any of the
following conditions:
1. Engine not running, or
2. Engine running and engine RPM greater than or equal to *KQASRPMD*, or
3. Engine running, engine RPM less than *KQASRPMD*, and base pulse width
greater than *KAPLH*, or if base pulse width is less than or equal to *KAPLH*,
then not in quasi-asynchronous mode and base pulse width greater than *KAPLL*.
Once synchronous fuel delivery mode is enabled, it will remain enabled until base pulse width becomes less than or equal to *KAPLC*.
Old Feb 11, 2012 | 02:59 PM
  #443
fasteddi's Avatar
Car: 1991 Camaro RS
Ok ill take on but dont laugh at the burnout i do in the garage...LOL
Old Feb 11, 2012 | 03:00 PM
  #444
fasteddi's Avatar
Car: 1991 Camaro RS
Ill try this tommorow, honestly im burnt up about the tuning for the day. im just happy i got the pin outs done, and got the NB and WB going thought the ECU correct.
Thanks for the tips though as i WILL try this tommorow!!
Old Feb 11, 2012 | 03:14 PM
  #445
RBob's Avatar
Car: check
Engine: check
Transmission: check
It very well may have been switching in & out of quasi-async fueling. That can cause incredible surging. Even more so when the injector compensation tables aren't set up correctly.
The other item about allegedly running that lean at idle is cam overlap. Get just a small puff of mix going out the exhaust during overlap and the WB isn't reporting the true in-chamber AFR.
Not sure why they don't eliminate the q-async mode and implement a single fire mode. Works much better.
What is interesting about the $58 code, is that it is a port of the early C3 turbo code. So much of the early code was carried over instead of creating $58 from a clean sheet of paper.
RBob.
Old Feb 11, 2012 | 03:24 PM
  #446
fasteddi's Avatar
Car: 1991 Camaro RS
Well i had to have a little shot of fun to end the night. Here is a video(dave made me take this) Of me ruining my garage floor with my tires.
http://www.youtube.com/watch?v=PlyJWQygYrw Dont laugh!
Heres what the first time I gave her gas did for specs. Max of 4.5psi of boost and AFR from 10.8 to 11.2 under boost and no spark knock/retard.
2nd time specs were 6psi of boost and AFR from 10.4 to 11.3. Absolutly no spark knock/retard.
On both of these recordings the higher AFR was at the low end of boost. The more boost the lower the AFR's went.
Now i was just playing arround as I cant drive this thing beause it snowed last night and I need to play with the Idle more, so this is just for amusement. And at least it was posi! Car wanted to move badd.. I just wanted to play a little as ive spent ALOT of hours getting this together in the last month or so...
I do love the fact that I can record the AFR in the $59 mask on tunerpro.
  #447
Ill try this tommorow, honestly im burnt up about the tuning for the day. im just happy i got the pin outs done, and got the NB and WB going thought the ECU correct. Thanks for the tips though as i WILL try this tommorow!!
Good deal. So the narrowband always worked, and it now matches the wideband readings properly because your wired it correctly. As for the idle, from what I was reading, the 13-14 air/fuel ratio at idle is common with $59 users, as even the administrator of Code59.org indicates that he can get a tame cam engine to reach 14-15 air/fuel and idle well, but tunes the more aggressive camshafts in the 13-14 air/fuel range otherwise it will hunt any leaner than that. Those are his own words. He also recommends disabling quasi fuel. Good luck with your build from this point forward Mark, as I am done with this thread. If you want that heater box just pay the shipping for it and you can have it for free. Thanks RBob for confirming everything...
[/done]
Old Feb 11, 2012 | 03:31 PM
  #448
fasteddi's Avatar
Car: 1991 Camaro RS
[/done]
Ok thanks Rob!! I dont know what was up with the sensor so I just used the simulated one into the ECU from that SLC controler.
Why are you leaving the thread man??? Youve been here the whole time, theres no sence in leaving it now! Dont let a few arguments take you away from the thread, you, dave, and sixshooter have helped me the whole way man!
Old Feb 11, 2012 | 03:33 PM
  #449
IIRC quasi-async is disabled in all starter bins of $59.
An O2 sensor that does not reach temp, or cools off at idle can certainly cause a forced open loop situation. This is quite common when people add headers and use the original non-heated O2 sensors to many vehicles, since the O2 sensor is then moved farther away from the exhaust port, and many times into area of cool air flow. I guess I now have to mention that this last paragraph was just for interest sake and in no way related to fasteddi's build, otherwise I bet I would get a quote and being told I'm wrong...
Old Feb 11, 2012 | 03:35 PM
  #450
project89's Avatar
u need to adjust ur bov , also u have to hook it to the manifold behind the throttle body it cant be hooked to the turbo compressor outlet, it has to see vacum when u close the throttle.
didnt seem like the bov went off at all in the video all i heard was compressor surge
